Fun Wire Pull
alaskan JW
Anchorage,Ak
Had a really hard pull this weekend. Pulled 3- 646 and 1-#2 DLO
cables 900' through 4in. Ocal. Maxed the tugger out to 10000lbs
and we had to have a come-along pulling on the clevis of the
sock when we finally got it out of the pipe. Wire megged out
fine so we were happy.
don_resqcapt19
Illinois
retired electrician
What do you use for bends? There would be a huge sidewall pressure on the conductors coming around that last 90. It would likely require a 90 with a 7 or 8 foot radius to bring the sidewall pressure down to an acceptable limit.
alaskan JW
Anchorage,Ak
We had to use DLO because the ampacity is twice
what a normal class b stranded wire is. They were
having voltage drop issues with the original
conductors that were installed. It was an existing
pipe run and it was the cheapest way for the coast
guard to do. There was a lot of pressure on those
conductors. We were very happy after it was all
done and they megged out. We are going to go and
test them again tomorrow, hopefully they will
megger out better.
don_resqcapt19
Illinois
retired electrician
There is nothing special about DLO that gives you an higher ampacity than standard building wire. You might think that if you just look at the manufacturer's info...they almost always list the 90?C free air ampacity. You can't use that DLO conductors that are installed in a raceway.
alaskan JW
Anchorage,Ak
They were worried about voltage drop and the DLO has 1600 strands of #24, thus more surface area then normal building wire. Why can you not use it in conduit? the insulation on it is listed as RHH.
peter d
New England
Let's see here...900' X 3 runs = 2700 feet of 646 kcmil DLO cable...Plus 900' of "ocal." I don't know that that is but from your pictures it looks like PVC coated RMC.
And you mentioned this was for the Coast Guard.
Apparently money is no object. ;)
benaround
Arizona
Alaskan JW,
Did you figure more than 475 amps per conductor for the 646kcmil ? Have fun
crimping the ends on the cables. 900', and that stuff fought every inch of the way.
don_resqcapt19
Illinois
retired electrician
You said that the DLO has twice the ampcity of standard Class B stranded wire. What I was trying to say is that you can't use the manufacturer's listed ampacity in a conduit as that ampacity is almost always based on a free air installation and 90?C ampacity. You can't use that ampacity for a NEC conduit installation.
jrannis
Yeah somebody really blew it think there is something special about DLO.
We use it in free air for some of its properties.
When it gets pulled in conduit (big mistake) its just plain ol RHW
SEO
Michigan
DLO cable is sometines used in cable trays for UPS systems and battery hook-up. As far as pulling 900' runs I would wounder if any of the strands might break under the stress of the pull?
alaskan JW
Anchorage,Ak
Some did break. We put two pulling grips in the sock and hooked the eyes in the clevis along with the pulling sock. The pulling grips ripped the strands from the cable. The set screws were still tight though :) .
benaround
Arizona
AlaskanJW,
Come on man, tell us the whole story!! What's the OCPD on this run, how
many amps did they figure the 646 is good for.
Want to hear something funny, My TV is on and the show is 'Tougher in Alaska"
even the wire pulling is tougher in Alaska.
