I was troubleshooting a detached garage sub panel today. The way the customer explained what was going on, I immediately thought they lost a phase feeding the sub-panel. I checked that first, and sure enough I only had 120v phase to phase. After looking for about an hour for where the phase could have been lost, and not being able to find it, I went back to the subpanel and turned off all the breakers. I immediately got 240v phase to phase. I turned on the breakers one by one, and there were a couple that made phase to phase voltage drop to 120v. When I turned them off right back to 240v. Fast forward eventually the panel was working with 240v phase to phase with all breakers on, but to be honest, I do not know how I fix them problem. I did unplug some things, and maybe one of those loads could have been the issue, but the loads worked fine when I left.
Has anyone run into this issue, and if so, did you figure out what caused the problem? This is the first time I have encountered something like this. Thanks!
