jeff43222
- Minneapolis, Minnesota
I had a troubleshooting call this morning like none I've had previously. Homeowner tells me that when he replaces a blown fuse with a new one, the new one blows immediately and a separate fuse also blows. I tried it myself, and sure enough, both fuses blew right away.
The house was built in 1960, and the fuse box is original (manufactured by Walker Electrical). Here's what I found in the box:
Brown wire connected to one of the blown fuses. Black wire connected to the other blown fuse. Red wire connected to another fuse as part of a multiwire circuit with the black wire. Black and red wires feed split-wired receptacles in the kitchen. Brown wire feeds the bathroom light/receptacle fixture, two bedrooms' lights and receptacles, and a hallway light.
If black and brown are both fused, both will blow. If black is fused and brown is open, nothing blows, and black's devices work fine. If black is open and brown is fused, brown's devices don't work at all (no voltage on hot). If black is open, red's devices also lose voltage, despite red being connected to a different fuse altogether. Red's fuse never blows. Black and red exit the fuse box through one run of Greenfield, and brown exits through another run. I found no evidence of black/red and brown meeting each other in any outlet boxes or j-boxes. None of the wires in the panel looked like they were connected wrong.
I opened up the outlets (red/black's and brown's) to look for shorts, but everything looked good. The only conclusion that makes any sense to me at this point is that the fuse box itself is the culprit. I can't think of a scenario where wiring downstream would cause this kind of behavior.
Anyone ever have one like this?
