ccernst
- Kansas City, MO, USA
I have a question about how fuses fail. I had a 3-phase power strip that uses fuses instead of breakers that had an issue. Fuses were SC-20 and load was less than 6 amps on each phase. The fuses did not blow completely, but manufacturer suggested I replace suspect fuses. Through measurements and observation, the affected fuses were off the "B" phase internal to the strip. Replacement fuses did fix the problem.
I did a continuity test on the failed fuses and they passed. I measured the resistance and it started at 3ohm and after about 10 seconds, it fell down to 0.0ohm. I checked another new fuse, same results. I've only experienced fuses failing by blowing the wire inside. My question is, do fuses fail in ways where they'd pass continuity tests?
