100 amp sounds about right for the feeder for the two pumps. You will then need to install a branch circuit with proper protection for each pump. What voltage are you using? A 10 HP 208 3-phase motor would be rated 30.8 amps, at 230 volts it would be rated 28 amps. What is a domestic pump? SOunds like you need to talk to someone with some experience in wiring motors or at least spend some time reading article 430.
