ChrisCentral
- Ontario
I have a 243A peak load which is normally protected by a 300A fuse; by code I have to consider the load continuous for this design by the OESC.
Can I want to replace the fuse with a circuit breaker?
Since the breaker is 80% rated I have to apply 1.25 to the ampacity of my load and I get 303.75A which exceeds the 300A breaker rating meaning the breaker will likely run hot and eventually fail so I should I go up to a 325A breaker?
The above are questions as I clearly am very confused.
Shouldn't the fuse be increase to 325A as well?
Or since the load is defined at 243A is there an oppourtunity or allowance to bring the fuse size down and decrease my conductor?
Are fuses 100% duty rated?
