So it's 50 amp circuit breaker feeding a 100 amp disconnect with 70 amp fuses feeding a motor? Can the motor start and run with the 50 amp circuit breaker?Is there a code issue to use 50A breaker(in elec. 480/3 panel) to feed an existing 70A, 480/3 fused disconnect, then a motor?
yesSo it's 50 amp circuit breaker feeding a 100 amp disconnect with 70 amp fuses feeding a motor? Can the motor start and run with the 50 amp circuit breaker?
If the motor can start and run then I don't see an issue with the 50 amp OCPD.
