Fused disconnect used as a panel
68Malibu383
Raleigh, NC
Came across this in a shed. Feed coming from house off main panel and this disconnect was fused. The shed had multiple receptacles, light fixtures and switches. Is it ever acceptable to use one of these for branch circuits?
iwire
Massachusetts
I can't think of a single reason why not.
qcroanoke
Sometimes I don't know if I'm the boxer or the bag
Roanoke, VA.
Sorta retired........
As long as it was connected to a properly sized breaker for the wire size used in the panel in the house all is good
qcroanoke
Roanoke, VA.
The breaker size at the house has to protect the feeder. The fuses in the disconnect have to protect the branch circuits
Agreed, I was more along the lines of saying it needed to be connected to a breaker and not just stabbed in front of the main as I have seen in some homes.
Some of the safer ones were pulling through the main fuses. not in front of them.
iwire
Massachusetts
Now I understand, that can certainly be sketchy.
OTOH If done correctly that can be NEC compliant, you can run service conductors out from the main structure to an accessory building and have a second service there.
qcroanoke
Roanoke, VA.
Ah! The old if done correctly clause! :)
