jsummers
- Newnan, GA, USA
I read in NEC2008 section 501.105(B)(5) the following:
"... fuses for overcurrent protection of instrument circuits not subject to overloading in normal use shall be permitted to be mounted in general purpose enclosures if each such fuse is preceded by a switch complying with 501.105(B)(1)."
I don't understand the thought process here and would appreciate some enlightenment. According to the first part of the clause quoted above the fuse is for overcurrent protection for faults that are not part of "normal use". If a fuse blows due to a faulty circuit condition, how does having a switch in front of the fuse make it any safer (from a standpoint of creating or preventing an arc that could cause an explosion)? Unless someone is there to operate the switch how does it help at all?
I would frequently like to fuse my I/O or power circuits in enclosures with low cost, standard fuses. All of the fuse manufacturers say that such fuses don't exist (the operating element either has to be oil immersed or in a hermetically sealed chamber). Does anyone know of a low cost way of providing fusing that still meets the code? (BTW, this question is assuming that all other components in the enclosure are C1D2 rated and I am using a General Purpose enclosure).
Thanks,
JS
Thanks,
JS
