FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
We use hot dipped zinc bolts to build docks over salt water. As the tide rises and falls, the bolts are under water and out of the water. That's what I call exposed to the elements. Not sure if I read a previous post in the intended context.
+1 on its use. i am just noting, given that zinc plays better with Al than SS does, and SS is ~2.5x more $$, to me a zinc item is a better choice. but as i noted, if the installer is not the owner of legal docs then just go with whatever is prescribed, can always argue the cause for future jobs as needed, etc.
if its a 50yr item that is described in the legal docs, i would use a coating under the lug, zinc hardware, proper locktite, and torque wrench. the copper wire (is it Cu?) & burndy will be dust long before there is a issue with bolt and Al.
