jeff48356
- Livonia, Michigan
Is there anything in the Code that says that a receptacle outlet for a garage door opener needs to be on a 20-amp circuit if it's a dedicated line? Many garages have subpanels with several breakers for various things in the garage. Would we be allowed to wire a garage door opener to a separate 15-amp circuit with no other loads on it?
Garage door openers don't use any more power than garbage disposals, gas furnaces, or refrigerators -- each of which is allowed to be wired to a separate 15A circuit.
