jaylectricity
 - Massachusetts
 - licensed journeyman electrician
The light blinks and it clicks but won't open.
I had to install a garage door opener receptacle in a garage and also refeed a receptacle just inside the door to the house from the garage because it was fed by an extension cord plugged into an extension cord plugged into a receptacle in a garage.
So to satisfy the gfci requirement for the garage (and have it readily accessible) and to satisfy the afci requirement for inside the house (replacement receptacle on modified circuit less than 6') I decided to install the dual-purpose receptacle just inside the house and feed out to the receptacle for the opener. Less than 30' of total wiring.
The garage door opener will not work. The light blinks and it clicks, but nothing else. I plugged it back in to the string of extension cords it used to be plugged into and it works fine.
There's 120v to each receptacle, I can't understand what the opener is detecting that's not allowing it to operate.
Any ideas? I shouldn't have even been forced to do this based on the scope of the work, but I agree it really needed to be done. Now I'm looking at yet another trip over here to separate the garage door opener to just a gfci protected receptacle.
