geochurchi
- Concord,NH
- Retired electrician
Hi All ,although it's good practice to put the openers on a separate circuit,what article requires it?
Thanks
Geo
Thanks
Geo
Was just talking about this article in the last thread I replied to, look at 210.23(A)(2). If they draw more then 50% of the branch circuit rating they can not have lighting or non fastened in place utilization equipment on the same circuit.Hi All ,although it's good practice to put the openers on a separate circuit,what article requires it?
Thanks
Geo
Commonly do you install dedicated circuits if there are double/triple door operators?I typically and have for years pulled dedicated supplies to the door openers.But not a direct circuit for each door.
More then you may think, but they still don't run long enough to be a problem.Just how often would you expect the doors to operate at the same time?
but if all three are already open and you are going inside for the rest of the night that is when you may poke all three buttons about the same time to close them.
