Thanks for your kind hospitality, IP -
Since my experience is in broadcast electronics I don't feel qualified
to sit with the many here licensed and steeped in code, much less with lifetime experienced specialized power electricians.
I could only discuss considerations scaled to electronic matters, as in these posts, attempting to compare grapes and grapefruit, only valid in that they're both fruits. I've only designed power and HVAC subsystems as an adjunct to the black art of analog, and then digital, broadcast studio design - systems (equipment,) cabling and timing (NYC.) Someone had to do it
and it had to work. I hear they still do.
I presume to post only hoping to pick their brains about how far to take the analogy in designing a safe and legal fed subsystem. But this is not MA, NY, CO, or CA.
Here's an amusing update:
We went to the local town hall to clarify local practice and requirements.
Unless (and until) I redo the roof, my plan for next summer, there are no permits or inspections needed for interior framing, finishing or wiring.
It was interesting when I asked about rewiring - One of the very friendly and personable female community elders (who run the tiny place, and know everything about the area and inhabitants' histories there is to know) looked back at another at her desk, and facetiously asked her if she'd like to go out and look at my wires. i.e. - There is no inspector (and incidentally no zoning.)
What they said about framing and wiring was, "Just go ahead and do it."
It looks like I'm the master of my own fate (and safety.)
I'll undoubtedly be doing more than they could ever require in that vein, and am glad to be able to do it properly as my experience and code research have indicated.
I will also be following code to whatever letter I can possibly reconcile with truly safe practice - if only to show off, and of course satisfy the insurance companies, should they ever care.... knock, knock.
I maintain the 8 steel poles constitute a ground grid, and so I might not reground. To clarify, the panel will be grounded with its own rod (or rather, the poles,) but that will probably not be used to reground the (4-wire 60a.) underground feeder, which will carry through as equipment ground, but in isolation on its own bar.
Anything else would create a loop, and ground currents,
with the Earth leg's impedance from service to fed system, providing an undesirable imbalance very similar to grounding the Neutral.
I will of course be removing the bonding of the neutral to ground which I currently find (inherited) at the panel feeder entrance, and create a second
-floated- bar for Neutral to carry it through to the outlets. This is one of many reasons I never considered seeking a local electrician. I may have done so for a stamp -should it have existed- for the insurance co. There would be nothing to stamp, LOL.
In Summary -
Out here in the mountains, they do not mess with what you do inside your own property. If they can't see it, they don't want to, and make neither provisions nor requirements for doing so.
Interestingly they do require registering a $10 permit when reroofing (but not when only repairing.) This ($10) permit lasts legally all summer - longer than, as they put it, ".. the month or so after which the ink will fade in the sun, becoming unreadable posted in your window."
There is no inspection involved. There is no inspector.
LOL, "Mountaineers Live Free."
Cheers,
Rod
lpelectric said:
Welcome to the forum. Are you on code-making-panel # 5? If not, you probably should be. :wink:
