I assume you are asking about determining general lighting load by the square foot, and I believe the answer is yes, but also beware 2014 NEC no longer allows other outlets outside of the garage to be on the same circuit as garage receptacles. But I think the garage receptacles are still included in the general lighting and you only have to count the square footage of living space and not include porches, garages, etc.Can garage receptacles (including overhead door receptacle) and lighting be connected to the dwelling unit general lighting circuits without including the garage area in the calculation of those circuits?
.....but also beware 2014 NEC no longer allows other outlets outside of the garage to be on the same circuit as garage receptacles....
Did anyone read the substantiation on this? Curious why they made that change.
That is what I am aware of as well. Not sure if I agree with how it turned out but that is what they left us with.I heard 110 volt vehicle chargers were the culprits. Not exactly sure.
That's an interesting reason.
It is not too surprising if you consider every three years they seem to add more rules that contradict what they have stated for years in 90.1 - "This Code is not intended as a design specification or an instruction manual for untrained persons."
