Where in the code is it required, (or not) the need to protect NM cable run in a garage, horizontally through bored holes in stud runs that are exposed (not covered with drywall?
Items can be hung from the cable for example, pulling the cable from its connectors. So is drywall or similar material required to cover the cables? And if so, where required in NEC?
Thanks
Thanks
