mdshunk said:No...
The violation is that you propose to run multiple circuits to a detached structure, when you're only permitted to have one, with a few exceptions. See 225.30 and
Not by the NEC. See 300.5(B), they are required to be listed wet.Dennis Alwon said:If the conduit is below grade you would have to run cable that is UG listed.
For it's wet listing, or direct burial listing? You can use THWN in conduit, right?In our area you must use UF cable if a conduit is used as a sleeve below grade.
Not all outside areas are wet, some are damp. 300.5(B) works to eliminate any confusion by requiring all underground installations to contain conductors listed for wet locations.Below grade is considered outside the building and thus must be listed for wet areas.
There has been a lot of discussion about what the conductors are inside NM cable - do you have a document that clears this up, or are you taking an educated guess like the rest of us?I know that nm cable has thwn in it but the jacket is not listed fot the use.
