GerryB
- woodbridge, ct. USA
I was wiring an Insinkerator gd today. I couldn't get the wire out, if you are familiar with this brand there is a piece of cardboard in the wiring compartment that says do not remove. I removed it and was digging around inside. After I wired it I stuffed the cardboard back inside. When I started it it was pretty loud, then it quieted down but still didn't sound right. Later the HO said it wasn't working. When I went to check it was humming but not moving like it was jammed. I turned it with the wrench, it didn't feel tight at all, it ran, stopped, ran again, stopped. I am thinking bad out of the box, but could I have damaged it myself digging my finger in there? I thought maybe I felt the windings in there.
