Re: Garbage disposal shut off switch
Originally posted by nascar03:
required a disposal switch be within three feet of the disposal. This was based on a call an inspector had made a couple of years earlier.
Well, this caught my eye.Started not to say anything but..The jurisdiction where I reside,and is just a local reqirements mind you.
Electrical contractors,that are doing residental wiring of dwellings units,are required in this jurisdiction to install a switch in a handy-box with cover(or,box w/switch cover, for the disconnecting means of a undercounter hard-wired dishwasher,regardless of the breaker-lock.
It is a "local requirement" in this area, for the sevicing of dishwasher w/ motor.
It's not a local requirement to be of the "ready accessible" location,but for switch to be in dishwasher cavity mind you,
behind the removable kick-plate,at bottom of the dishwasher unit ..(*where said, to prefer to have it)
"This enclosure" that switch is mounted in,doesn't need to be attached,or even secured to unit..But will be present.
This came to mind,after the reading of his "Local Inspectors" requirements of his motor-rated appliance..And wondering,if others are being required, in doing the same for their "dishwasher/appliance" in the areas of their AHJ's, requirement also.
Edited:-O-F-F..can still be present,on the door.
[ June 08, 2005, 06:35 PM: Message edited by: dillon3c ]
