360Youth
- Newport, NC
stew said:I also use one 20 amp circuit for dw and disp. and always cord and plug both at the same split receptacle. never had a problem , If its not code compliant no one has to this point ever called it.
It just depends on your listed loads. It never occured to me either until I came across that set of specs that had a 13 amp disposal. Last thing I wanted was a brand new 7000 sq ft house to be tripping breakers because they happened to flip on the disp. while the DW was running. All it takes is once.
