HoosierSparky
Senior Plans Examiner, MEP
- Scottsdale AZ
- Senior Plans Examiner
Is there a code requirement for separation distance between electric and gas lines in a common trench? Is it even allowed? I have looked in the Uniform Plumbing Code, International Fuel Gas Code and the NEC. It is not addressed. The plumbing codes require separation between water and sewer. That makes sense. City water tastes bad enough. Most underground gas is in Yellow plastic pipe with a tracer wire. If you used UF cable and ran it on top or right next to the gas line, it wouldn't seem right, but I haven't found a code section to back that up. Ideas??:?
