shortcircuit1
- USA
Hello,
When you are doing the load calcs for a multifamily or single family residential unit when they specify all the ranges,dryers are going to be gas and the water heaters are going to be gas instead of electric do you still include the gas range kw,dryer kw and water heater kw in your load calcs?
Another question i have read that if its a gas range you generally provide a 120v receptacle for ignition.Now where does the 120v receptacle getting power from?Small appliance circuit?Same question for the water heater as well.
Thanks,
shortcircuit.
Thanks,
shortcircuit.
