goldstar
- New Jersey
- Electrical Contractor
I don't believe it's required but I can tell you, as a matter of fact, that I have had a problem with a range igniter being on a GFCI circuit and nuisance tripping. I don't remember if I ran a separate circuit after that or just tapped into an non-GFI circuit but that solved the problem. Nowadays, I just don't take any chances and I just install a non-gfci circuit for the range. Nobody likes to do double work.Has anyone ever heard of inspectors not allowing the receptacle for a gas range be GFCI protected? Since they can be on the SABC they usually end up being wired from the counter receptacle and GFCI protected. We have an inspector here in NJ who makes contractors ensure that the range receptacle is not GFCI protected because if the GFCI trips and someone could turn on the gas and it would never ignite. In his mind this is a good idea.
Hope you're not working up north near me. I have enough problems with certain inspectors who like to make up their own rules. Sometimes they just like to run things up the flagpole to see if they fly. If you know you're right I would challenge him, in the most respectful way of course.:thumbsup:
