hhsting
- Glen bunie, md, us
- Junior plan reviewer
In gas station scenario with convenient store and has separate outside the store canopy with steel structure under which are gas station dispensers like any normal gas station.
Following questions:
1. If structure or building is allowed to have one feeder or branch circuit then would not the canopy be structure but it has more than one branch circuits or feeders to dispensers and speakers etc. I don’t see panelboard with main disco, GES or one branch circuit at the gas station canopy. Why would it not have to comply per NEC 2014 section 225.30? The gas station canopy is not a structure?
2. I have cell phone antennas on top of the gas station canopy and it has its own 200A utility fed from overhead on canopy. Here is the dilemma if the gas station canopy is considered structure then grounding electrodes do not have to be same or bond to building convenient store electrodes. However, if gas station canopy is Not consider structure then building convenient store grounding electrode should be used. Am I correct?
3. Question #2 regarding grounding electrodes your opinion how does it work typically?
