451F
A contractor is asking:
1. Is watertight flexible metallic conduit permitted if it is equipped with seal-offs at each end and only contains intrinsically safe wiring? (I don't think the wiring should be used unless it is listed for the use as fumes can cross the seal-off inside of the sheath.)
2. Do pump (STP) conductors have to be in explosion rated flex AND jboxes? (YES)
Thanks for your opinions in advance.
