I don't see a lot of GE panels in my area, so I'm not used to the breakers that are available.
The panel in the house I'm working in now has a 200-amp GE panel that it says is a 40 circuit panel, but that's only if you use the 1/2" breakers.
I see several 2-pole breakers in it (dryer, range, etc) that are the 1" style breaker. I haven't pulled one of them out to look closer at them.
How is a 1" 2-pole breaker able to "straddle" both phases on the buss bar? There are also several "normal" sized 2-pole breakers in the panel.
The reason I ask is that I need to add a couple of circuits and I want to change some of the normal sized breakers to the 1" 2-pole breakers to help make space for the circuits I need to add.
Also, do they make a 1/2" AFCI breaker? I'm assuming not...
