jjsparky
- Westminster, Colorado, USA
- Superintendent I/E
From the main distrubution panel, about 600' away, we have a welded steel stand with a 480 volt disconnect, 480 v to 208 v transformer, and then to a 120/208 panel. I know the transformer needs a ground rod. There is nothing else around. But does the 480v disconnect need to be connected to tha ground rod? I'm using 250.32.
