76nemo
- Ogdensburg, NY
Had to put in an outdoor SquareD service panel today for an empty lot, (pole mounted). The grounding bar is isolated from the box itself. It was freezing cold and the bonding screw had ******* threads. At 10 degrees on the river bank, I wasn't cranking anything to try to make the threading. I am curious. Does it say anywhere I can't bond the box to the GEC, and NOT use the bonding screw on the neutral bar???? That's where I was going, but I didn't know if it was allowed. I was frickin' freezing, so I just went on and will return over the weekend, not a rush job.
So,..... question stands. Does it state anywhere in code I MUST use the bonding screw if the box is bonded otherwise?????
