Can you change the raceway protecting the GEC from Steel RMC to Aluminum LB to Steel RMC in a continuous length. How does the Bonding of the GEC to the Steel raceway at both ends work?
I think the answer is avoid this type installation.
Yes, you can use aluminum fitting with steel RMC in most locations (344.14).
A bonding bushing is threaded onto the male threads of the conduit or the tubing connector, having a lug that you can use to connect a jumper from the GEC to itself.
