JOHNEO99
- Northern Illinois
Ok heres the scenario. I have a 600 amp 6 gang meter bank outside with each meter having its own disconnect/breaker. There will be six panels inside the building with main breakers instead of main lugs to different offices.
I know the GC, EG, and GEC should terminate at the same spot at the main disconnect.
How is the main disconnect determined in this situation? Is the main disconnect considered to be at the meter bank or inside at the panel main breaker.
I would like for the panels inside to be considered the main disconnects so i dont have to bring 6 GECs back to the meter bank. I would just run GEC from each respective to water supply/copper in each unit.
