ELI56
- Tacoma WA US
I am installing a 400amp residential service.the general contractor did not install a ufer grounding system.In talking to the inspector my best bet is to chip into the footing 20 feet apart and clamp onto the rebar and then test for continuity.What I thought the inspector said to do was run one run of #4 copper to the footing and then at the panels splice a second #4 with nonreversible clamp to #4 so as to connect to the other panel.I have never been in this situation,have always ran separate conductors from each panel to the ground rods in the past.Any help would be greatly appreciated
