Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
Yes I know this has been beat to death, so I apologize in advance.
My reading is the GEC, which must be a continuous conductor, is from the panel, (in my case) to “a” point on the GES.
So for example, I can come out of my meter main combo, to the first ground rod. This is the GEC.
From there, I can run a separate conductor to the gas line, water line, and second ground rod, as those are bonding jumpers, and connect those to the first ground rod, and those are allowed to be separate conductors to each.
My situation is, I want to use armored ground cable, which can’t be run continuous through the clamps made for them, so they will have to be individual conductors.
