Gec
Is table 250-122 right for the grounding to the water meter from main disconnet? Which would be #6cu for 200a?
No see 250.66.......would require a #4 reason that can carry a fault. The sole GEC is only for objectionable current as in stray lightning current....simple analogy only.
Is there a requirement to bond the water meter ???? :D
even with PVC piping ?:)
As I jest, I also jump on my soap box and say that don't understand why a metal water pipe which is not a grounding electrode must be bonded per 250.66 where "other metal piping" does not carry such requirement.
It's on the "street side". It is a being used as a grounding electrode.
If the water main is plastic coming in from the street or well it does not meet the requirements of 250.52 A 1, so 250. 66 would not apply. In my area ( se Mass ) all local insp. except one use 250. 122 for this situation.
agree BUT 250.104(A) uses 250.66 also
