Hello,
I found a few posts regarding this and I always come out without the exact solution I was hoping for.
Say you have a 200A Service Entrance Rated Generac ATS. The ATS has all of the required labeling for "Emergency disconnect service disconnect", such as the below example:
Now, these ATSs have only one breaker inside. It is a 200A breaker and it turns off the utility feed. Once this happens the generator will automatically turn on. If the generator is at some other location, there needs to be some sort of signage on the ATS indicating where the generator is.
What part of the code allows a second emergency disconnect? (in other words, makes it code compliant to have the fire fighter have to disconnect the utility breaker inside the ATS and then go to the Generator disconnect and turn that off)
What part of the code specifies the size of the signage?
What part of the code dictates the format and what must be written on the generator location signage?
