stickboy1375
- Litchfield, CT
chris kennedy said:Mabey your not doing it right.
I love you man... but they come blown from the factory... :grin:
480sparky said:My guess would be the ATS is detecting what it considers an under-voltage problem.... it's looking for 240 and sees 208.
active1 said:If your not a Generac / Guardian dealer I don't think you will be able to talk to a factory tec support. They allways ask for dealer dealer account information if I call them for anything. Non dealers get refured to local installer dealers. I have not been impressed by the tec department. Seemed like I get a part time student / worker sitting at a PC answering the phone.
That's when people like me get a phone call like this:
We bought this unit at the box store because they had the best price and had someone elce install it. It does not work... Can you tell us how to fix it? Or can you come out and repair it under warrenty (and get paid what the factory decides a few months later after several phone calls)? That's when I say sorry we're booked up for months and I can't fix it over the phone.
I'm not jumping on you, I figure you did a fine install. Just saying don't expect much from the factory.
charlie tuna said:i have done two generac sets in the 11 kw size --- both times upon testing for the first time the generator transfer switch would not transfer back to the normal power source???? so we shutdown the generator set and of course it transfered from emergency to normal... we thought we had a problem??? ran the unit back through another test and it worked as designed from that point on??? is it in the program or what???
stickboy1375 said:? If utility source voltage drops below about 65
percent of the nominal supply voltage, the sensor
energizes a 10 second timer.
