I am looking for some help in regards to the general lighting load tables in the NEC. I am a Prime Power Specialist in the Army, so I do not really use too much of the NEC. I deal with higher voltage installations and aspects of medium voltage power generation. I am currently enrolled in a NEC class and we are going over service calculations. Part of the service calculation is the general lighting load. The chart clearly says for the type of structure what the demand is per square foot. Then once you have figured that out you go to the demand factor chart to determine your multiplier. My question is if you have a restaurant, which will be a continuous load, does the NEC already take that into accout when you use the 2VAs per square foot, and you go to the demand factor chart and it tells you it is at 100% or do you have to then multiply by 125%. The NEC does not say you have to multiply general lighting by 125% if its going to be a continous load like a restaurant would be however we are being told we should. I am looking for some help on clearing this subject up. thanks
