stickboy1375
- Litchfield, CT
nanckekr said:This is how I am reading it now, and in a way it makes sense. I believe the reasoning behind is the assumption that a short circuit in an applience a user has connected to a receptacle is higher than the risk of a short circuit in a ceiling light, which the user will interact less with.
In the event of a short circuit, you do not want to loose the light in the room, as then you can not find your way safely to the breaker box. By totally separating the light circuits from the receptacle circuits you are lowering the chance of ending up with no light in a room in the event of a short circuit somewhere in the system.
I recall from Northern Europe, that we do NOT separate the two circuits. Guess what: when something went bad, you sat there in complete darkness, wishing you were a smoker and thus equiped with a lighter to show you the way to the breaker box![]()
I don't believe that is the reason at all, other wise we would just be required to install emergency lighting. IMO, it's simply a load issue...
