alaskan JW
- Anchorage,Ak
I am wondering if i can use a 120/277 volt rated, double pole single throw snap switch as a disconnect for a single phase 240v 2hp motor. the switch is rated at 30 amps.
The real question i had is if that rating-120/277 is a line to neutral rating and not a line to line rating so can it still be used as a disconnect even though the motor is 240v line to line load. I am thinking no but i am not sure. Does a line to line fault have more short circuit current then a line to neutral fault? I am thinking yes but i do not know the theory behind it.
thanks
thanks
