mark32
- Currently in NJ
An acquaintance ordered and received a 14kw (Generac) generator and asked me to give him a hand since he knew I had installed the same one earlier this year. The generator in question has a short whip coming off it with a junction box at the end of it, which mounts to the house in which the FMC whip from the ATS hooks into. One of the problems is there are two a/c units sitting in the chosen location prohibiting proper distance to be achieved for the generator's whip to reach the house. The other issue is the panel, where the ATS needs to be, is on the other side of the house, no way the ATS's whip will make it that far. (Not to mentioned that level is entirely finished and in addition to that the only place to put the ATS has about five timers and an alarm box mounted there, all of which would have to be moved somewhere) If the equipment is installed in the locations that he and the customer chose (Main issue is the generator's location which the customer chose so as not to be an eyesore on the service side of the house, she even managed to have the meter installed inside) the gen's whip would have to be replaced and the ATS's whip would have to be lengthened by splicing somewhere in the middle as there are connectors on the end of both whips that plug into each other in the jbox. I want to help this guy out but there are too many obstacles not to mention cutting/replacing those whips will likely void any warranties. What do you think?
