I bought a diesel generator from China for many years. 50kva 4 stroke, Cummins engine, Stamford ac generator, recently, the generator fails to start, something wrong? any professionals tech me how to do, urgent help??
I am not a professional mechanic but I've had diesel car and diesel generator along with propane and gasoline models.
Diesel engines are a whole different breed. I'm sure that for five years that you had your generator, you probably have some familiarity in terms of its eccentricities.
Some suggestions are valid. . . but you need to proceed with some sort of priorities in order to come up with some meaningful course of action.
The suggestion that maybe the brushes are worn does not make the cut. A diesel engine can start without the generator making electricity.
I would start on the fuel system.
Though diesels don't have spark plugs, you need a good healthy battery to energize the glow plugs before you can crank the engine.
Diesel viscosity changes with temperature—one reason truck drivers don't shut their engines even in an overnight rest in truck stops. I spend a lot of overnight stops with these guys on my trips across the continental US in my RV.
I don't know how handy you are in dealing with diesel engines. Check the fuel system first, the pump (usually mechanical) filter and an air-bound fuel lines.
Also, diesel can breed bacteria in the fuel tank that can build up inside and restrict flow.
If this is too intimidating for you-- call a diesel mechanic.
