Twoskinsoneman
- West Virginia, USA NEC: 2020
- Facility Senior Electrician
445.13 Ampacity of Conductors.
The ampacity of the conductors from the generator terminals to the first distribution device(s) containing overcurrent protection shall not be less than 115 percent of the nameplate current rating of the generator. It shall be permitted to size the neutral conductors in accordance with 220.61. Conductors that must carry ground-fault currents shall not be smaller than required by 250.30(A). Neutral conductors of dc generators that must carry ground-fault currents shall not be smaller than the minimum required size of the largest conductor.
If your generator has a built-in OCPD, do you not use the 115% rule? Or since the OCPD is mounted on the gen do you consider it the gen terminals and not a "distribution device"
