Hello everyone. I'm new to the forum. My background is with generators but I'm now in the transformer business. In an effort to help some of my customers, I'm trying to understand certain situations. I've been given conflicting answers to a couple scenarios and was hoping for some input.
First scenario:
1,000 kW generator 277/480 volt feeding a 1,500 kVA transformer with a 4,160 Y / 2,400 primary and 480 Y / 277 volt secondary.
Since this transformer is being "back fed" and is being used as a step up, I have a grounding question. This is a temporary installation that is feeding a 600 amp 5 kV fused disconnect with the appropriately sized fuses.
How should the transformer's neutral (XO) be managed? XO left floating, XO tied to ground or XO tied through an NGR. Why ?
How should the transformers high voltage neutral (HO) be managed? HO left floating, HO tied to ground or HO tied through an NGR. Why ?
How should the generators neutral connection be managed? Left floating, tied to ground or tied through an NGR. Why ?
Second Scenario:
Same as first except the transformer is a 4,160 D to a 480 Y / 277.
How should the generators's neutral be managed?
How should the transformers secondary neutral be managed?
If any of this is unclear, please let me know.
I'll be looking forward to a response.
Thank you !
First scenario:
Second Scenario:
Thank you !
