I have a 20RESA kohler Generator and a RXT 200 AMP ATS that I need to install in MA. The meter is around 100 ft away from the house.
My plan is replace the actual meter for a Homeline 200 Amp 8-Space 16-Circuit Outdoor Ringless Overhead/Underground Main Breaker, (need the 8 space for future pool equipment and small shed close to it)
then feed the ATS and
then feed the house panels inside from the ATS. The generator will be close to it, so will be far from the house canceling the noise a lit bit
I am journeyman electrician, this is my first generator job, so I am not sure if this is the best way to do it, any advise will be very much appreciated.
Thank you
Thank you
