I thought that we only paid for true power?Originally posted by charlie b:
One difference is worth noting: The customer pays for the KVA (ie., including the KVAR), not just for the KW.
We don't here. Our POCO uses kilowatt-hour meters. They have a surcharge for industrial users that have low power factors.The customer pays for the KVA (ie., including the KVAR), not just for the KW.
Charlie B., you know better than that. The customer pays for real power and may pay a power factor penalty, but watt-hour meters do just that; they meter watt-hours, not volt-ampere hours.Originally posted by charlie b:
Not a bad analogy, Ed. One difference is worth noting: The customer pays for the KVA (ie., including the KVAR), not just for the KW. It's kind of like paying for the milk bottle at every delivery cycle, and not getting a refund when you give the empty bottle back. Sort of a bad deal, huh?
Steve, you have it backwards. Vectors can be represented as complex numbers, but a complex number is not necessarily a vector (phasor). Your statement is obviously a response to my claim that power is not a vector. I make this claim for several reasons:Originally posted by steve66:
Any complex number can be represented by a vector.
We were talking about "vectors", not phasors. No sine waves are required for vectors.Power waveforms are not sinusoidal. This is a requirement for phasors.
Once again, that has nothing to do with vectors.The frequency of the power waveform is twice that of the AC voltage and current. Phase has no meaning for signals of different frequencies.
Again, vectors, not phasors. But vectors do also require a phase angle. The phase angles that we have are the angles between "VA", "VAR", and "Watts". It's called the "power triangle".Power has no phase angle which is a requirement for a phasor.
Wrong. See the item above. "VA", "VAR", and "Watts" are added vectorially.Power is added algebraically, never vectorially.
I don't know why you would refer to two sine waves (and all the information we can deduce from them - like their relative phases) as "scalars". That's just ignoring half the information you are given. Would you also say that "20 feet Northwest" is just "20"? And again, vecotrs, not phasors.Power is the product of scalar quantities, therefore it cannot be a phasor.
Sure they are. Multiply two sine functions together, and you get (drum roll) a sine function - Frequency is twice and the phase angle is changed, but it is a sine.Originally posted by rattus:
That's true, but why sould one want to compare the voltage phase angle with the power angle. One application I've seen for power angle is comparing two generating sources that one is planning on connecting. I can't say it has come up very often in my business - okay maybe never.Originally posted by rattus:
That is indeed the problem - it looks like one.Originally posted by coulter:
Rattus -
Complex power looks like a vector to me.
carl
I chose this site to explain the parallelogram law of addition because it emphasises the concept that "A vector can be seen as relative changes in position."vector: A mathematico-physical quantity that represents a vector quantity
vector quantity: Any physical quantity whose specification involves both magnitude and direction and that obeys the parallelogram law of addition.
mathematico-physical quantity (abstract quantity) (mathematical quantity) (symbolic quantity) A concept, amenable to the operations of mathematics, that is directly related on one (or more) physical quantity and is represented by a letter symbol in equations that are statements about that quantity. Note: Each mathematical quantity used in physics is related to a corresponding physical quantity in a way that depends on its defining equation. It is characterized by both a qualitative and a quantitative attribute [that is, dimensionality and magnitude)
