- Mission Viejo, CA
- Professional Electrical Engineer
Re: Generator KVAR?
"Real Power" is the scalar product of the instantaneous current and voltage vectors. The cosine of the angle between the instantaneous current and voltage vectors when they are "linearly translated" to a common coordinate system and their ordinate points (tail) matched is the is the power factor.
If we added a 10hp and a 200hp motor to the same bus, we would rarely even think about the fact that they had significantly different power factors.
[ April 09, 2005, 10:30 AM: Message edited by: rbalex ]
Well, you do have to choose the correct vectors and multiplication technique. There are two vector multiplication techniques; one yields a vector (also called the "cross" product), the other yields a scalar (also called the "dot" product).Originally posted by rattus:
One more time:
You do not multiply vectors to obtain power. ...
Sometimes the process gets in the way of reality; but usually for practical applied engineering purposes, "close enough is close enough." The "vectorizing" of power computations is useful because it "works" and results in values close enough for practical use - but it isn't reality.When it was common to use such tools, the young engineer found the veteran quietly working on various long computations with his slide rule and a pad of paper.
Interrupting his mentor's work he asked him, "What's two times two."
Absent mindedly, the senior began manipulating the rods and cursor, "Well, let's see it's 3.99..., Ah hell, make it four."
