Hello to all.
I Work as a maintenance man in the building. There is a new cooling tower getting installed next to the building.
Right behind new cooling tower is a new backup generator is being installed. Also cooling tower shut off valves right above generator, maybe 5-7feet away. The question I have is with water, moisture and chemicals, that are used for cooling towers, should it be a pretty large distance between this units? I know you can't have any water over electrical gear. Anybody know, so any problems in the future can be avoid it? Any help would be appreciate.
Big D.
Big D.
