JohnJ0906
- Baltimore, MD
"PTO generator"?
Power Take Off.JohnJ0906 said:"PTO generator"?![]()
mdshunk said:Power Take Off.
Connects to the back of a farm tractor just like a brush hog or manure spreader or any other impliment. Just gotta toy with the throttle a little on certain tractors to get the voltage right. More or less a generator head mounted on a little trailer with the shaft piece to connect to a normal tractor PTO shaft.
cowboyjwc said:I've never seen the interlock. Does it act like a manuel transfer switch?
But this install does beat the guys that just strip off the end of the cord, attach a breaker, turn off the main and back feed the panel
Uh-huh. Square D makes a kit for most of their panels. Other manfuacturer's do as well. Lemme blow up that section of the pic. Check back...cowboyjwc said:I've never seen the interlock. Does it act like a manuel transfer switch?
That's just the little walking beam. I forget the part number for the whole kit. I know I'm going to take a beating for this, but I keep one on the truck. I'll just go out and look and take a picture ('cause nobody would believe it). :grin:480sparky said:Part No QO2DTI.
jdsmith said:So who makes the appropriate 3R male inlet that an extension cord can be connected to? I've seen them at Home Dopey and the like but my supply house couldn't figure out what to sell me for a generator inlet. I will note that I normally do commercial work and the supply house is more oriented that way, but it's rare they can't find something to meet a request. Can anyone provide a specific product link?
Also, is the cord SOW? Do they sell a reasonable quality cord or do people typically fabricate them?
480sparky said:What voltage and amperage would you like?
They sell these at Home Depot, but you can just as easily mount a Hubbell flanged inlet in the bottom of a 3R enclosure:jdsmith said:So who makes the appropriate 3R male inlet that an extension cord can be connected to? ?
jdsmith said:240/120V (4 wire) 20A or 30A
The other question: twist lock or striaght blade?
Ditto, but mostly because that's normally what the receptacle on the portable generators is in the first place. Make everything "match".480sparky said:I always recommend twistlock.
480sparky said:I always recommend twistlock. You don't have to worry about anything vibrating or getting pulled loose:
120/240V 20a power inlet Pass & Seymour # L1420-FI, 30amp is L1430-FI. Just go the the P&S Site and search for those numbers.
mdshunk said:Ditto, but mostly because that's normally what the receptacle on the portable generators is in the first place. Make everything "match".
I know they sell pre-made cordsets for these things, but they're crazy expensive (in my opinion). The factory cords are made nice, though. I generally make my own, mostly due to availability issues with manufactured cordsets.
