chaterpilar
- Saudi Arabia
There is an installation where they have 8 CAT 3512BTA 1600 kva engines in sync.
They run at around 60% load each.
The ambient ( room temperature is 55 deg C) and the alternator winding temperature is rising upto 115 deg C.
Now, the question is is this winding temperature is acceptable ( It is Class H insulation) but alternator name plate specifies 105 deg C rise at 40 deg C ambient.
Will increasing the ventilation,reduce the problem this high temp rise?
Presently there is a substantial negative pressure in the room...it takes effort to open the door of the room.
Is there any formula to calculate the ventilation for a generator room?
Any thoughts..
Any thoughts..
