We are planning a generator install. An automatic transfer switch will be added at the service entrance (Generac RXSW200A3)
Current Meter Box and Service Disconnect are conjoined (see first image in the link for existing). The transfer switch will be placed to the right of the existing service disconnect box (see second image for proposed).
I know the point at which the initial service disconnect is made should be the locations where the neutral gets bonded to the ground. So I will have to reconfigure a couple things in the existing service disconnect box. The ground and the neutral conductors coming from the main load center (bottom of first image, main load center is not pictured) will need to be spliced and extended into the transfer switch's box and connected to the bonded ground and neutral bars there.
It shouldnt matter if I leave the ground electrode conductor as is, correct ? (i.e. connected to the Ground/Neutral Bar in the service disconnect panel) or should I move this connection also into the transfer switch's ground bar? I have seen it done both ways.
images:
drive.google.com
images:
Generator - Google Drive
