papa smurf
Need help in Iraq. I'm inspecting an electrical substation that the main power is coming from 5 large Diesel Generators. The Generators A.C. output is 3phase 400 volts A.c. The Generator has a 3 PHASE 1600 amp 3 pole breaker mounted on the generator and then feeds a y - delta step up transformer. Steps up to 11k volts. The Neutral from the Gen. and the Neutral from the y 400v side are going to a ground rod grounding grid. Not sure if that is correct. The secondary 11k delta side is going inside to the 11k switchgear breaker and has no neutral, but this cable is armored and they are grounding the armor at the generator to it frame which is grounded to a ground rod grid system. The other end coming in at the switch gear is grounded to the gear frame. That equip. ground on the gear goes outside to another grounding grid with 2 -70mm wires to a ground rod grounding grid. Which actually means both grounding grids are tech. grounded together. The 11k leaves again with 3 wire armoured cable by means of another 11k breaker and goes to a step down transformer, 400v on the secondary, Primary is 11k delta - 400volt - y secondary. The armor again is grounded on both ends.The frame on the transformer is grounded in a 400volt outside panel to the ground bar and then that bar is grounded to another grounding grid consisting of 4 ground rods located 6ft apart. I believe the neutral on the sec. should be tied to the grounding nut on top of the transformer also. This outside panel has a main and 5 breakers that feed 5 building. The Neutral and ground are not tied together in this panel, and not sure if this is correct. The wire feeding the building is only 4 wire with no ground feeding a 3phase panel. If I'm correct shouldn't there be a ground going to the building also. They have another grounding grid at the building with a ground coming from the panel but like i said no ground feeding the panel from the first means of disconnect located at the step down transformer. They have no way to run another ground to the building panel. Would it be OK to run a ground from the first means located at the transformer to the grounding grid located at the building and meet the ground that was run from the building panel. Your expertise is well needed at this time please. Tried to explain the best i could and hope this helps. THANKS.
